Hi everyone,
I’m seeing a weird issue with the SunnySky X3520 (520KV) motor.
Same ESC (Flycolor Flydragon Lite 120A), same 6S 5000mAh LiPo battery — but sometimes the motor cuts off during the first throttle-up, especially drawing around 45–60A.
What’s strange is:
I tried two different 6S LiPos — one Profuse 5000mAh 60C, the other Forceup 5200mAh 25C — both show the same behavior.
But with a 6S 12000mAh Turnigy Graphene, the problem never happens.
Also tested with an X4120 (550KV) + 15×8 prop, same ESC, same 5000mAh battery → draws 80A with no cutoff.
The X3520 uses a 14×8 Eolo prop, so it’s not even under heavier load.
Most of the time, the cutoff happens on the first run. After that, the motor usually works fine — even with the same battery.
Seems like a current spike or voltage sag issue, but why would X4120 handle it fine while X3520 fails, even under lower load?
Any thoughts on what could be causing this?
Thanks
What’s strange is:
Thanks
