in need of dremel help
Arrow
Westfield
i gave up trying to grind a screw down manually(sigh)
anyways. what dremel will i neeed and what bit will i need to make a notch in a countersunk screw in the chassis
You will just need a basic dremel and i would just use a cutoff wheel. Not sure what kind of notch you will need but this should do the trick
Dremels rule.
If you're trying to notch a countersunk screw you'll more than likely take away a bit of the chassis with the cutting wheel.
If you want to minimize scarring of the chassis you can make your cutting wheel smaller by running it against a dressing stone.
ok i picked up the dremel and cutting wheel today
got the screw out successfully.
about a half centimeter of raw aluminum on both sides not to bad right? tried to keep the dmg to a minimal
