You should always adjust the idle's final setting with zero trim and full brake applied. Since the same servo works the throttle one way and the brakes in the other direction, you need the idle screw to stop the throttle before it goes far enough to stall.2hy would you use the idle screw to control the idle? Instead wouldn't you just use the LSN?
