qaart
Gone - bye bye.
convert it to pull start it be around 50$ to replace
pull start is 20$ its lighter all you depend on is your glow plug igniter.
if the batt is dead in the easy start you can't start the truck
http://s538.photobucket.com/albums/ff343/qaart/?action=view¤t=GEDC0112.jpg
look behind that motor see if there is a number
http://s538.photobucket.com/albums/ff343/qaart/?action=view¤t=GEDC0113.jpg
theres a more clear pict
Get a manual! Don't mess with changing the ez start. It works fine. If yours is broke, it's cheap to fix. Get a MANUAL and search the net. It sounds like your new to rc, so take your time and be patient. The more info you read, the better off you'll be.
That says TRX 3.3
Okay. first advice on this site I can give you is anything qaart says, don't listen to him.
As far as your maxx, it looks like it was taken care of except of the dirt. The engine looks to be in very good condition and looks like it wasn't overheated. It is the classic version of the maxx, but looks to be one of the last batches they made due to the fact of the color of the cooling head.
As far as cleaning goes, spray it with some simple green and let it soak in for a minute and then spray it off with an air compressor. anything else, scrub with a toothbrush.
And your EZ starter, it it the battery you lost or the wand (part that plugs into it that turns over the motor?) if it is the wand, let me know and I can send you one if you cover shipping. But i would advise you just go and buy a pull starter. It may be a little frustrating at first when you don't know how to tune but saves weight off your truck and is a good choice.
Bottom line though, is you have a truck that is 5 +/- years old and is outdated. There are parts on that truck you can not get any more and you will have to switch to the newer version if/when you break parts.
Besides, pull starters just plain suck.
