it doesn't use a standard servo or a micro servo, it uses something in between, and i can't find anything thats the same size onlineYou bought a standard servo. You need a mini servo it looks like to me. Measure the servo and order correct size.
can you link one? most of them arent the right size, the base of the motor should be 31 mm x 16.6mmlook on amazon just looked there's many search was ,mini servo..383 results
ig i found one on amazon but it seems cheap, ill try it thogo to servo city .put in you numbers then you can make a file folder with what servos will work. Sorry not doing your work!
Knowing what car it is, and what scale, would help possibly narrow down servos that will fit.View attachment 168374
since it’s bigger i doesn't fit into the stock mounting place.
