Hi there having problems tuning this hyper 8 port race engine. seems its ok when on the cold side 200 degrees but when it exceeds 250 degrees its jetting starts to change. The engine will get hotter to 300-320 degrees and loose power . Then I richen it to keep temp down and it will stall when the throttle is squeezed to full .I suspect this is a common problem with this composite carb. Still under warranty. (mistake, mistake) Any help is great. I am an accomplished tuner. So please don't tell me its the settings.
All settings are adjusted when the engine is at 220-250 degrees.
