hpi savage x 4.6
hlddrum
i just got a new motor for my savage and I'm haveing an issue getting the wheels to stop turning in idle whats the best way to fix that
Turn your throttle trim back to neutral, or zero. You also might need to adjust your throttle linkage.
...and if that does not fix it you likely have a problem in the clutch. Reversed or weak springs causing constant drag against the clutch bell.
Here's the Savage clutch setup...
