HPI RS4 Stage D drift build #1
Defiant
  3. Flying
I’ve always wanted to build one of these, so a while ago I ordered this new Stage D kit with plans to convert my RTR drift into a Stage D car. So I began collecting parts slowly to make the ultimate nitro drift missile!
For anyone who wasn’t aware, the RTR nitro drift chassis is different than the Stage D chassis. Servo mounts are different, material is different (6061 vs 7075), one is made in Taiwan and the other in Japan, they cannot be interchanged.
First thing I did was rip out the single speed gearbox from the RTR, swapped out the spur from a 47T to a 44T, and mounted it to the Stage D chassis with a Hot Bodies center gearbox mount. I also installed a Yeah Racing steering assembly but this will not be in the finished car.
Next I tore open a rear diff from an RS4-3, installed the diff cup from the Nitro Drift, an HPI diff locker kit, and put the assembly back into a brand new plastic housing
Installed the rear diff assembly and driveshaft, and while at it I fitted the brake kit from the Hot Bodies edition RS4. Purple brake cam lever is also from there.
Steering servo mounts and carbon upper deck installed temporarily
Rear shock tower is the original Hot Bodies design, impossible to find nowadays
And so this is as far as I’m going to get today. Progress will continue as I acquire more pieces. Minor details will all be ironed out by the time it’s complete
I got a RTR version of this one, one of my favs. Love it.
Do you reckon the Stage D conversion is of better quality/design/workmanship that RTR counterpart?
Thanks
Thanks
Quality is standard Hpi quality which is to say, excellent. There is no difference between the two apart from the Stage D chassis being made of a superior grade of aluminum. The great thing about the RTR is that it’s cheaper, is mass produced/more accessible, and is very easy to disassemble.
The only flaw I noticed on this car is the top chassis plate which you got in fiber, its quite soft and bends easily.
Where did you get yours from, eBay?
It’s part of the stage D kit and can only be had that way unless you get very very lucky and someone lists theirs up for sale, but people typically want too much money for these upper decks.
A member is working on creating aftermarket upper decks out of carbon fiber to provide a cheaper alternative but it’s going to be a while until they get sold to the public.
Grabbed an old seized engine and prepared it for the RS4
Everything disassembled ready to be cleaned
Back together
Tight fit with the brakes and all but it works, check out that rare hi-power tuned pipe
Today I rebuilt a spare front diff I had and put it in some new plastics
I also did the fuel lines and air filter
I decided to try and make my own purple foam bumper, this one came out ok. I finished it off with some carbon fiber and some purple standoffs
Up next is suspension
Very nice!
Those engines are good, if a bit finnicky to tune, the idle has to be up a little, and cannot go lower to what I'd like it to be at.
After seeing how Kyosho engine idles, I have been spoilt a little.
Which spray paint do you use?
Nice!
Where did you find purple foam? Since you are making these and selling them, maybe you should look into one of these...
Podoy Hot Wire Foam Cutting Machine Working Table Tool for Cutting Foams Sponge Pearl Cotton KT Board DIY Styrofoam Polystyrene Cutter Electric Heating https://a.co/d/339KHkJ
You can build one nicer for a lot less money.
Nice!
Ooh that’s neat, I’ll look into that thank you. I’m not sure where I got the foam, it was in my storage pile so I’ll have to dig through all my purchase history to find where it came from. I suppose I could consider making more
Very nice!
Agreed, Kyosho engines idle amazing! And what do you mean by what spray paint do I use?
I was just curious because I'venever seen that foam in anything but black or gray. It looks like it may be a yoga mat maybe?
If you use a piece of 1/4" hardboard and make a template of the bumper, then drill a tiny hole for a thumbtack at each end, you can just stick it to the foam. Then you can just run the wire around the template to cut the bumpers out.
I used to do a lot of foam cutting for dioramas. They are great tools for lots of stuff. But I just made mine with Rene 41 wire and a power supply. There are vids on YT.
The cooling head, did you not spray paint that?
Dam that thing is purty! Lets see the body on it and some run time!
