My HPI Remote doesn't seem the same anymore. Ever since i changed the spur gear it has been kinda, well not the same. The spur gear has nothing to do with the problem cause i narrowed it down to the radio. This is kinda hard to explain but ill try anyways. Whenever i turn on the radio and the electronics the carb stays open. I did a lot of tuning with the idle and the throttle tuning on the actual remote and the remote tuning thing is maxed out and the carb is still almost at half throttle. i had another remote laying around so i put the crystal in that and tried it and it worked exactly how it used to. I'm pretty sure its the Remote considering that other remotes work normally. I could use the other remote but i prefer the HPI one. Does anyone now what the problem is, i have fresh batteries in the remote and in the truck also, so if anyone has any suggestions id apprectiate it.
thanks
oh and i checked all the settings on the remote like the switces that reverses the throttle and steering so that is not the problem either, i checked everything.
thanks
