Supernitro17
well i should first say that i had the engine running well several times, i guess id say through a little more than half a gallon of fuel, maybe more. i just switched to 30% nitro (by error of towerhobbies.com which is my only curent supply of rc stuff) and i was retuning, i had it running wel for a bout half a quart, and then decided to maybe try and tune a little more. i had the high end needle all dialed in , and it was fine, or so it seemed. i was adjusting the idle and set it to fast enough so the clutch just barely didnt engage, however it did have some roll out here and there.. but nothing big.
The engine never smoked or anything, so I'm pretty sure i wasn't running to rich at all, i think i was on the lean side. but now ! ... there are "burn marks" on my rear exhaust (just brown stains kind of from i guess the heat, which should have been an indicator) and then the engine stalled out as soon as it got started. i tried to fix it with some success, but now the thing just flat out wont start at all. i set the high end back to factory setting, and then tried everything with the low end needle, but nothing works. ... also , the pull start is hard to pull and feels jerky , not like it used to, and it also has a hard time reeling back in pretty often now... anyone have any idea of what i did , or what i can do to fix it ? or should i just get a new engine and actually treat it the way it should be, and have it set up , and not mess with it anymore. this was my first nitro engine, so I'm glad i ruined a cheap engine if its ruined... and i guess I've learned my lesson... for new engines I'm looking at ...
STS SR3 3 port
sts outlaw turbo (i dont race or anything , just bash around)
team orion turbo
OS (not sure which yet, probably a cx-r or whatever it is)
Fantom.
Thanks for any input , I'm really stumped on this
STS SR3 3 port
team orion turbo
Fantom.
