How do I aim my TempGun using the laser?
For our models PE2 and PE-3 , aiming from a distance is made easier by use of a red sighting laser.
The red laser is offset from the TempGun’s infrared sensor by one half inch. The laser runs PARALLEL to the center of the sensor. This means that from 3 inches away, the laser is one half inch from the center of the temperature measurement. From 20 feet away, the laser is STILL one half inch from the center of the temperature measurement.
This means that from a very close distance, say three inches or less, the laser IS NOT going to be at the dead center of your measurement, ya dig?
In the RC Hobby, measuring nitro engine temps, you are trying to measure a spot a quarter inch wide down inside the head of the engine. This is typically done by putting the TempGun (regardless of brand) directly over the top of the head. If you do it that way, your sighting laser will be cast one half inch off to the SIDE of the head, and not down the middle at all. THAT IS FINE. Your concern should be with the positioning of the INFRARED sensor at that close range, and not the goofy laser. If you do indeed shoot the red laser down into the head, you will actually be measuring a half inch away, probably down the side fins of your engine. Do you dig it now?
The sighting laser will ALWAYS be one half inch from the center of your measurement. For those insistent customers, I will custom build a parallelogram reflective mirror system, in a snap on configuration, that will compensate for this offset, so that regardless of distance, the laser is always spot on, dead center. The fee for this custom accessory is 5 million U.S. dollars, payable by certified funds two weeks before start of production. Better get in line for that add-on right now!
NOTE: The red laser that is available on some of our TempGun models DOES NOT measure temperature! It is a separate beam that simply serves as a pointing device. The surface temperatures are measured using an invisible infrared sensor. The red laser can shoot a very long distance, across the hall, across the building, across the street. The INFRARED sensor only shoots (effectively) a short to medium distance, depending on the model’s D:S ratio. So while you can use a “laser gun” and see a red dot on the wall 50 feet away, you ARE NOT measuring the temperature of that far away wall, but rather a general average temperature of a large area (from 50 ft). No infrared TempGun is any good at measuring empty air ambient temperatures.
