What were your first parts to go, I have only busted the motor guard and stripped a spur gear. I've thought about replacing the motor guard with an aluminum one from ST Racing
Only problems I have had is tires,spurs, drive shaft and the stock motor. I change the stock esc and motor to a Mamba Max/ Feigao 10s and have not had on min of trouble. It will run 60 mph when I can keep it down and on the ground. Oyea, I did rub a hole in the roof from 40 mph roof slides.
I've bent one shock shaft and had to replace the motor. The velcro adhesive also tore off the sideguards (but not the body). Other than that she's still going strong.
first thing i notices was the easy diff action (will be filling my wiht high temp wheel bearing grease) and the body roll *(will be getting new pistons/oil or all new shocking system)
Tore up my first spur a few weeks ago. Other than that the rear bumper keeps popping out where the side rails run along the outside of the rear skid plate (or is it the motor guard?), but only on the right side. Wierd!
...rear bumper keeps popping out where the side rails run along the outside of the rear skid plate (or is it the motor guard?), but only on the right side. Wierd!
