How is it different (Factoid)
FastEddy
The Slowest Guy In Town
RCTalk Vendor
El Dorado Hills, CA
Super Glue (Factoid)
What makes super glue so super? How is it different from
regular glue?
Super glue deserves its name -- a single drop can permanently
join your thumb to your index finger faster than you can say
"Whoops," and a 1-square-inch bond can hold more than a ton.
So how does this remarkable substance work? The answer lies
in its main ingredient, cyanoacrylate (C5H5NO2, for you
chemistry buffs).
Cyanoacrylate is an acrylic resin that cures (forms its strongest
bond) almost instantly. The only trigger it requires is the
hydroxyl ions in water, which is convenient since virtually
any object you might wish to glue will have at least trace
amounts of water on its surface.
White glues, such as Elmer's, bond by solvent evaporation. The
solvent in Elmer's all-purpose school glue is water. When the
water evaporates, the polyvinylacetate latex that has spread
into a material's crevices forms a flexible bond. Super glue,
on the other hand, undergoes a process called anionic poly-
merization. Cyanoacrylate molecules start linking up when they
come into contact with water, and they whip around in chains to
form a durable plastic mesh. The glue thickens and hardens until
the thrashing molecular strands can no longer move.
FLATTOP
llama boy
That's interesting Eddy, isn't CA glue similar to super glue? is it basically the same thing?
Retread316
Adrenaline Junkie
CA = Super glue...
CA...IS super glue...the CA is the abbreviation for cyanocrylate.
Yo - Fasteddy...thanks for the chemistry lesson! I love stuff like this...
FlyinRazorback
RCNT Addict
"And now you know the rest of the story....Good day!"
MountainMan
Surely, you don't want us to believe, you figured that all out by yourself. Do you?
El Pirata
RCNT VIP
2nd Star to the Right
So if superglue requires water to dry then why can you put a lit cigarette near the wet superglue and it will dry faster?
Çh®i§tiªñ
RCNT VIP
I'm going out on a limb here, but, I would say the heat evaporates the water at an accelerated rate which expedites the curing process.
Maybe?
I dunno.......
El Pirata
RCNT VIP
Re: Super Glue (Factoid)
Originally posted by FastEddy
Cyanoacrylate is an acrylic resin that cures (forms its strongest bond) almost instantly. The only trigger it requires is the hydroxyl ions in water, which is convenient since virtually any object you might wish to glue will have at least trace amounts of water on its surface.
Was this not saying that it needed water to cure so how would heat expedite this? That's the question
[email protected]
RCNT Addict
Re: Re: Super Glue (Factoid)
Ya know how heat dries you clothes? It turns water into gas form. Water is the only element that can sustain three forms. Liquid, solid and gas. Seeing that breathable air is made up of mostly hygrogen (water). When introduced to heat it concentrates to gas making the water content more dense or humid. So you see, heat itself from the cigarette doen't help, it's the water that accumilates around it.:cool:
Candyman
'Cuse is in the house!
Syracuse, NY
My guess? The particles in smoke may thicken the glue. Kinda like flour. The same thing happens if you sprinkle baking soda on it. It's an aircraft building trick. I used it on the last wing I built. Lay in a bead of medium CA. Put in the wing rib. Align it. Then dust with baking soda. Hardens instantly. No waiting.
Candyman
Syracuse, NY
Noo dude, I was guessing. Hell, that's what I'm doing half the time I'm here!!!!!! :D
Besides, I didn't see your post before I replied. We were only like a minute apart...
[email protected]
RCNT Addict
The four elements are earth, water,
air, and fire.
Air can be solid? No, Fire can be solid and liquid? No_OH yeah, Earth can be gas, no. So El. Water is the only element that can sustain the three basic forms.:banana:
Sorry dude I didn't mean to come off like a a$$. Sometimes I word things the wrong way:eek:
El Pirata
RCNT VIP
Actually water is not an element, it is a combination of elements, 2 parts hydrogen and one part oxygen. These are actually elements that can sustain the 3 states we were talking about including a ton of more elements.
Candyman
Syracuse, NY
Chris, I have no clue what the baking soda does. I just know it works. I picked that one up from Model Airplane News. It works really well. Just make sure everything is aligned before you dust it. Cuz that stuff firms up quick..
Çh®i§tiªñ
RCNT VIP
I have to remember that one - I'm going to be putting together a slo stic flyer for indoor real soon. Thanks for the info!!!!
[email protected]
RCNT Addict
I'm talking basic elements not molecular. Sure we can break down any form of matter into molecular elements. earth is comprised of a mutitude of elements, but as a basic, not molecular element it can not convert to a gas. I believe the table of molecular elements to not apply seeing that I based my answer on water, not Hydrogen or oxygen as separate entities.
WoodiE
Replies
30
23K
Greywolf74
Greywolf74
SMaxxin
Replies
19
14K
dixon
D
