how do i install the rc-solution cage
pissant
can someone give me pictures on how to install this body. its impossible
Did you try and read the included instructions?
You will find them to be quite helpful.
installed that last week. instructions were kinda vague...i think it was meant as a general instruction guide for all trucks. here's how i installed it step by step
- remove stock rollbar and exhaust
- install the chassis mounts (two aluminum table things) with the obvious screws
- assemble the cage, if its not obvious, the rear has the body mounts in the lower back
- screw in the allen screws in whatever order you wish just remember to use some loctite
- now hold up one side and position the v shaped pieces
- the two v shaped pieces should be positioned jutting outwards (away from the chassis)
- screw in the other side with loctite again
- dremel the cups off the bumper mounts and the bumper mount posts (remember to only do the sides touching the chassis, take your time, you want it to be as flush as possible)
- put the cage on top, screw it to the chassis mounts with the nutscrews and screw it to the chassis plates with the allen screws
- finally screw it to the front and rear, between the bumper mounts and the bumper mount posts. put your exhaust back in, find the new mounting holes for your body and dremel away
thats what i recall..someone correct me if I'm missing something
Pissant you can always go to the RC solutions manufacturer forum and ask scottm he is a direct representative for the company and I am sure would be happy to help you.
when i installed my rcsolutions cage, it took me about an hour and all the instructions i needed were in the instruction manuel. it was pretty straight forward.
savager
