How do I fit a LRP Z.21R in a tmaxx
@Huggybear87 I believe you're going to need to find a big block chassis which is going to be pretty hard to find anymore. Best bet would probably be to check eBay as I can't think of anyone right off hand who still makes a BB chassis for the T-Maxx.
After looking on ebay it's going to be cheaper for me to buy an OS .21TM than it is to get a big block chassis.
I'll just look to see if I can find a cheap 1/8th buggy for sale at my local RC club and drop the LRP into that.
Thanks for the reply @WoodiE
Then ofcoarce ,if you have metal skills...you can make your own!...:p
I thought the LRP .21 was a small block motor??
I'm not sure what revolves on a Tmaxx chassy ,there maybe room issue ,but if the issue is
the engine mount ,an chassy engine mount holes ,holes are slotted to adjust the engine.
AE's monster truck engine mount is slotted to move the engine back & forth.
If one would have the room on chassy ,you can drill new holes ,an find the bit for a dremel
to slot them for adjustment.
The main issue is that the chassis is too short to fit the engine in as well as a header. You could maybe move the trans forward, but not sure you can gain enough room.
