Hop Ups For RS4 3
pckx
I'm looking to get some hop ups for my RS4 RTR3, i already have the os .15 cv-x engine, a 2 speed tranny with smaller gears, a new Exhaust, and foam tires... What else can i buy...also any sites that i can buy the parts from???
There is alot you can do, check out my gallery to see some pix of my RS4 3. You can buy the stuff from towerhobbies or check e-bay.
U can buy a graphite upper deck, front and rear graphite shock towers, a sway bar set. a better steering servo if the one you have is crappy, thats all i can think of right now. you can buy all aluminum parts! you will have tons to buy. you can buy a lightened flywheel and the nitro racing clutch as well. there soo much you can do wiht this car.
I have on my RS4 3......stiffer shock springs, sway bars, adjustable turnbuckles, THS pipe and header, carbon fiber shock towers front and rear, set of Jaco foams and set of rubber tires, ofna fail safe, futaba FM receiver, MIP CVD's front and rear, carbon fiber upper deck, modified throttle linkage, motor saver air filter, fuel filter and five cell hump pack rechargable battery..........more to hop up
dose anyone have any suggestions on a good engine, (fast), i'v been looking at the o.s. .18 cv-r... dose anyone have any suggestions???
C48 put a XTM .18 into his rs4. that engine supposidly has alot of low end torque the o.s. wouldnt be a bad choice neither.
Yeah, it has tons of low end punch. It takes a lilttle bit of cutting to fit in but its definetely worth it. (Only like 5-10 min extra time for cutting) At 99 bucks, its definetely a good value.
