HoBao Hyper SC 2.0 1/10 Scale 4WD Short Course Truck🤩
RustyUs
Military Veteran
Build Thread Contributor RC Showcase: 9
Pennsylvania, USA
What have we here?
ARR and RTR versions available.
Differentials:
  • Center differential is directly connected to rear differential.
  • Front, Rear and Center Differential, Metal Bevel gear, Anti-leakage Differential housing.
  • Pinion Gear: 10T (MOD 1)/ Ring Gear: 39T (MOD 1)
  • Center Spur Gear: 40T (MOD 1)
  • Motor Gear: 13T (MOD 1)
  • Front differential filled with #20K silicone oil.
  • Center differential filled with #9K silicone oil.
Rear differential filled with #5K silicone oil.
Suspension:
  • Front PBS
  • New design steering block with enlarged pivot ball and alum steering arms.
  • Optional alum steering block set #OP1-0077; Alum rear hub #OP1-0079.
  • New strengthened composite upper arms and lower arms.( Also Fitting for older versions of the Hyper 10SC)
  • Optional carbon fiber arm insert#OP1-0068 and #OP1-0069
  • Front & rear anti-roll bars.
  • New Alum front and rear arm holder.
  • Front and rear CNC alum arm holder with pill inserts#11367, adjustable toe angles and anti-squat angles.
Shocks:
  • Filled with front #700 silicone oil and rear #600 silicone oil.
  • Alum 12mm Big Body, 3.5mm Shaft, Alum Adjustable Ring, Shock Cap Protector.
  • Spring:
    -. Front: 0.86kg/cm, L=50mm, Blue
    -. Rear: 064kg/cm, L=65mm, Blue
    -. Optional Front Spring#OP1-0073: 1kg/cm, L=50mm, Grey
    -. Optional Rear Spring #OP1-0074: 0.73kg/cm, L=65mm, Grey
    -. Shock Tower: 3mm CNC alum
    -. Optional carbon fiber shock tower, Front tower #OP1-0070 & Rear tower #OP1-0071
I know this post is a year old but pillowball cars are kind of rare in 10th scale? Although SCT tend to be closer to 8th scale
nitro touring cars (and the serpent 7xx-e line, basically serpent's electric version of their 10th scale nitro car) as far as i can tell are the only 10th scale vehicles that really use pillow balls although they use it front and rear
I love the rollover protection in the body mount setup, very cool. Is that unique?
Hobao's Hyper 8SC and Hyper 10SC 4wd platforms (2010-2011?) came with those roll bars as well.
Shouldn’t be too heavy to do much to the center of gravity, right?
I can't think of any other 1/10th scale platforms, off the top of my head, that use a pillow ball suspension other than Team Durango DESC10/Arrma Senton 6S. Then again, they were both based off of the1/8 scale DEX8 buggy chassis.
