A hex screw head on my car is stripped and is completely rounded so no screw but will grab. What’s a way I can remove it?
Got a link to a "rectangle black stone"? I've had to do this a lot, but usually end up notching whatevers behind the screw, if I could avoid that in the future by making the cuttoff wheel smaller, I'd like to.you can use a Dremel and use rectangle black stone to make diameter of cutoff wheel small enough so the carbon fiber chassis is not damaged . a left handed drill bit ..heat that loc tite up with either a solder iron. or another way
Use an "easy-out". It has a reverse thread. Get it at the hdwe store or on-line.A hex screw head on my car is stripped and is completely rounded so no screw but will grab. What’s a way I can remove it?
