It just doesn't pull period or it doesn't grab the shaft and spin the engine?
If it doesn't pull at all, as in it's stuck, then the engine is probably hydro locked. Remove the glow plug, flip the engine upside down, and spin it a few times. You should see fuel spray out.
If it doesn't spin the engine, just clean the one-way bearing in some brake cleaner or denatured alcohol.
