cbaker65
RCTalk VIP
Here ,sometimes seeing a vid helps1
@Rolex I didnt touch the idle nor the HSN. I only tried to bring back the LSN to factory. Thoughts?
I have the new model of the Mad Crusher and the manual does not give a turn count for the LSN. The LSN does not bottom of by design. The LSN is actually on the throttle arm, and not across from it.
I got off the phone with them and I was told to do the following:
"It is 4 1/4 out from closed. So hold the slide closed then turn the needle all the way in until you feel the slide wants to move, then back it out 4 1/4."
ok so that point when the slide wants to move is the bottomed out position. the needle still seats against the throat of the carb, not the slide so as you are tuning it have the throttle opened slightly so the needle is not pushing against the mating surface.I have the new model of the Mad Crusher and the manual does not give a turn count for the LSN. The LSN does not bottom of by design. The LSN is actually on the throttle arm, and not across from it.
Good! definitely follow his advice as far as tuning as they will know the engine better than anyone. i would start on the HSN be aware as you will most probably need to richen the LSN as you lean the HSN. keep with pinch testing as you get your tune closer. the needles are separate and change different part of the power band, but they work together to achieve that.Update: I followed Derrek's advice (Kyosho America) and I turned out the LSN 1 turn from flush. The engine now turned on with 1 or 2 pulls. HSN is still trich and if I accelerate too fast it Boggs. Will adjust that later.
Right now engine dies after a 3 second pinch test, pinching thr line as close to the carburator nipple as possible.
When I run at 1/2 throttle and stop engine does not shut off, however, I believe arPM gets higher and if I hit the throttle it returns to normal. Should I leave as is and move to HSN adjustment?
It idles idles for at least three minutes, that's the longest I tested it. Temps are at 70C.
@D3MON @Rolex: I had my tune and I lost it. Now I have a couple of questions:
1. Yesterday I went out and I couldn't start the engine. After some attempts my reaction was to start playing with my LSN. I wasn't able to start it so I then started to play with the HSN. After it, I lost the tune. Should I have tried to start it more with the settings I had? Use a little throttle?
2. I am now using the tuning chart provided by @Rolex to get my tune back. I have return the needles to factory setting. It wont cold start idle how it used to, and it wont start the same way. Which brings me to the question: how should I start the engine? Use some throttle? How should I warm up my engine during a 70F day? When I had my I would start it with 3-4 pulls, kept the glow igniter on for 10 sec, then I would let it idle for a min until RPM increased slightly. I was able to hear it.
3. If my engine wont turn on once I have my tune back. What should I do? I feel I should not mess with the LSN.
