HELP PLEASE! Arrma Felony
ApacheBone
I switched out the 16 tooth pinion for the 23 tooth. Does the higher gearing make it louder? Also there’s hardly any coast at all. Almost as if some brake is being applied. Is this normal with higher gearing?
it should not have made it any louder . and you should still have coast unless to tight of gear mesh or wrong tooth gear added(as in incorrect pitch). Id check all gear mesh and correct gear pitch..
