help os 21tm
crxej1
houston tx
i been searching and couldnt find anything
what part number for ths tuned pipe to fit os 21tm
i seen some that fits t maxx 2.5 and 3.3 but will the ths manifold fit with the os motor?
or any input on 1pc rd logics tuned pipe??
thanks
It's a standard 1/10 type manifold port. Ones that are directly compatible with the TRX engines won't work if they are "one piece" (header connects to pipe via gasket and springs). Traxxas manifolds are annoying in that regard... then all aftermarket won't work with anything other than TRX exhaust ports if it isn't a drop in (replace stock) header.
I'm guessing you have the 21TM and are looking for a better pipe to run with it? What pipe do you have now?
Small block manifolds work good on a trx or picco if you use a piece of revo exhaust stinger for a gasket. I've done this many times with great success.
I have a standard associated header on my jato, I just drilled new holes so I could use two springs vs one. Seems to work ok that way with a normal gasket.
