Hi
Please can you help me i have just purchased a HSP Bazooka with a 0.21 engine. I have done everything that is says in the instructions (needle valve 2.5 turns from closed)about pre starting the buggy. I managed to get the buggy started after a little bit of priming, it then ran for about 3-4Min's then started to cough and splutter a little then cut out. We then struggled to get fuel down the fuel line even when priming it, the fuel would come down the line to the carb then return half way back down the fuel line. I had to open the needle valve some more then prime it again, it would then maybe work and put the fuel into the carb. Finally when i did get the fuel line full the car would just do the same as the above we did this 3-4 times then gave in and i am now needing your help!
Please please help, my young son is so upset his daddy can't get the buggy to go.
Many thanks
Steve Reed
Many thanks
Steve Reed
