Hi,
I am a real noobie to the hobby and I have a brand new HPI RS4 3 RTR. When I first got the car and was going through the initial 'getting ready' steps, such as fitting the batteries, I noticed that the steering and throttle servos were twitching, just a little bit, when the car was turned on and the radio was on. I thought nothing of this (being a noobie, I figued it was harmless interference or something)....
.....Shortly after getting the car started, the car took off (straight into a damn wall....fortunately, the car was only superficially scratched). Since this accident (ie, during the remainder of break-in) I have had the car on a block to keep the wheels off the ground...but twice during the tank, the car just caned it into full throttle and I couldn't stop it with the radio. It also twitches the wheels as well. This only seems to happen when both the car and radio are on. If the car and radio are off, but I have the engine running.....it idles fine.
Does anyone have a clue what could be causing this? I have checked all the cables for a loose connection, double-taped the radio and batteries in place in case it is a vibration problem but still the problem persists. I have almost finished the break-in cycle, but there is no way I am letting this car loose if I can't control it!!!!!
Help!!!!
Thanks
P.S. The tqitching seems worse if I move the transmitter around.
Help!!!!
Thanks
