Hi all, I have a OS .21 tm it has a little over half a gallon on it. I noticed yesterday that dirt was collecting on the side of the block and it looked oily (dark and wet) so today I took it out and removed the flywheel to have a look at the bearing and sure enough there was oil on the bearing. I cleaned it up and put some soap water on it and blow on the fuel line, there was some small bubbles forming around the crank and the bearing (so thats where its leaking). Should I contact OS about it with there 2 year warrenty only had it for a month and bought it new? Now heres my other problem I went to remove the rear plate to see and clean it up, well OS use's screws and I had 3 out and on the last one it striped now I can't get it out, what are my options? Thanks in advance for your help
Shawn
Shawn
