on everyones XTM cvd's that are breaking are you breaking the pins on the dogbone pin side, the cvd pin side, or the shaft itself? if you are breaking the pin on the cvd side (the pin which can be rebuilt from xtm's parts) i found this fix that i got from someone on a different forum, I'm sorry i can't remember his name or what forum it was from if your reading this. take a titanium drill bit, #39 fits the best, stick the shaft part of the drill bit into your cvd shaft and coupler and cut to lenghth. thats the part i always broke on my xtm cvd's, and after this fix i have yet to break another cvd. the xtm cvd pins have a groove cut into them to fit the set screw, this is the inherit desighn weakness..I've found the drill bit shaft hold fine without the groove. you can get a titanium bit for about 3$, and make about 3 cvd pins...peace---
