Help Again
reu_beu
http://www.casadaigreja.com/nitro.htm
Can you help me to identify the brand of the engine and car of my nitro.
How can i deal with this ;
When i start the car cold is very easy,,,but if i ran for 5 minutes is almost impossible....
A roto start will help ?
Thnks a lOt
:angry: :n00bie: :thankyou:
it maybe a kyosho sumthing or other but dont take my word I'm not good with buggies. But for the engine not restarting your probobly running too hot which means your running lean so try richening it up a bit.
Try your low speed setting initially, but you may want to richen both of them out... have you hit it with a temp gun? What temp are you running at?
High speed needle is the flat-head screw that is inside of the brass fitting that stands out of the carb assembly. The low speed I'm not sure where it is on yours (don't konw what engine you have), but more than likely it is at the end of the throttle linkage... right in the middle of the slider, there should be a flat head slot. It may be on the opposite side of it too... but quite often the flat head slot is the middle setting for the carb if it is that style with 3 settings. The one thing that is for sure is that the screw head that is in the brass thing is the high speed setting.
suppaduppa said:
Wheres the nitro cleaner?
AMEN to that! Clean that up before you do anything. Especially that mill!! Two things to use. First....Denatured alcohol! Second..Nitro clean on the cooling head!!
Yeah dude... clean that baby off first, I wouldn't even as much as take the air filter off before cleaning most of that crap off of it.
oKOKOKOKOKOKS....
And some help about tune it... barand of the motor ?
Hello :
I got a new one....now my car with the engine stoped ...and if roll the whells the piston noves....??????S???S?
Force21
Do you know where can i find information about the engine a Force 21 with pullstart
Also in the manual of the car, see the link I posted above. Or do you need more information?
yah dude you seriously need to clean that thing up.part of the reason your engine is overheating is because there's so much friggen dirt in the fins
Yeah, what ever you can... even a damp paper towel or cloth to run inbetween the fins if you have nothing else... something to get that crap off. BTW, you need better quality pic's too.
