- In my recliner
- Flying
- Thread starter
- #61
Latest updates:
Trying to get 3 wheels to rise together with 2 servos was a MAJOR chore, but finally they are working nicely as a team.
After all the work of getting the stock heli up and running, here's what it had to get torn down to in order to be mounted inside the scale fuselage. The entire tail rotor assembly also had to be removed, while leaving its drive belt inside the tube.
Here's the initial test fitting:
Here are 4 perfectly balanced blades, balanced with the tape on the balancer you see, and set with a laser level.
Blades set in the rotor head.
New rotor head mounted in heli.
Final grinding and fit testing on the fuselage.
It's getting close!
It's getting close!
