gx-15 spec?????
backlash92
co durham
  1. Racing
hi everyone I've just ordered a gx-12 and a gx-15 and just wondered if anyone knows the spec on these engines ie. are the reliable, what is the cc, top speed,reccommended temp,best fuel anything really I'm new to the hobby and I'm egar to learn about the engines any info would be much appretiated its rolling on a kyosho pure ten alpha is this a good car ? also any ideas on what its worth everything is mint with new engine to be fitted gx12 or gx15 any suggestions ?
Nitro engines = MAX temps range 250 - 270 Deg's No matter what engine I am useing " I use Traxxas & HPI powerplant's in my rig's " each nitro engine co will have " THERE " MAX engine temp's range for "example" Traxxas say's not to exceed 270 deg's with there engines & HPI states 250 is MAX for there engines.. You will have to look @ your engines manual to see what thay state is safe engine temps....
Nitro Fuel's = I run Blue Thunder 20% nitro content is my personal choice
But everyone is different there are alot of choices for Nitro Fuel's out on the market today just to name a few & pretty popular
Traxxas Top Fuel
Odonnell
HPI
VP Fuels "new fuel out but alot of guys that race @ my HS track started using this fuel"
So it's mainly up to you & brand you want to go with...
Any NEW Nitro engine should be properly BROKEN-IN & your manual should state how many full tanks of fuel it will take to acheve proper engine break in...
For example Traxxas states thease are there step's for a new engine break-in
1. Run 1st tank of fuel with all wheels off ground " on a stand " NO THROTTTLE " idle only
2. Tanks 2 - 3 run Veh with 1/4 throttle input's only
3. Tanks 4 - 5 run Veh with 1/2 throttle inputs only
4. Tanks 6 - 7 run Veh with 3/4 throttle inputs only
5. Tank 8 run veh with 3 second's burst Full Throttle
after thouse step's are followed your engine is properly broken in "But IMO I take it easy on my engines until I get 10 -12 tanks of fuel before I really start letting it RIP.
Hope theas tips help you out....
Traxxas Top Fuel
Odonnell
HPI
thanks this is very infomative do u have any idea on the cc and top speed ????
Nitro engines are classed buy there size .15 / .18 / 2.5 / 3.3 Example a traxxas 3.3 engine is more powerfull than traxxas 2.5 engine... So CC's IMO are hardly metioned or listed 98% of Nitro co's revert to the size itself "IE" .15 / .18 / 2.5 / 3.3 & So on.... Engine displacment I havent have the slightest clue "but I am shure it's listed somewhere in the manual" & again I MYSELF Go buy the engine size like I stated above.
Top Speed's = Vary example a Traxxas 2.5R engine has a top rated speed of 48 MPH for a 1/10th scale Veh... " & Veh were are talking about is a T-Maxx "
Now drop in a Traxxas 3.3 engine "into a 2 wheel rear drive Rustler" now you looking @ around 55 - MPH " you ask WHY reason being 1. Rig lighter & 2 wheel drive / 2. bigger powerplant / You get the idiea....
