gooseneck trailer project
majin
My love for RC: Intact. My RC cars: Not so much
kentucky
  3. Crawling
  4. Scale Builder
here we go on the next project
i have a gooseneck trailer but its doodie.
need to either upgrade it or use it as a template to build another. hoping to get guidance and ideas from the squad
can you weld? and if yes do you have a welder and what type.MIG,TIG.SMAW? other wise that thing does need help. how are wxles secured? do they have bearings? Id start by adding some corner bracing... and a tube of PC 7( its black when it hardens I use a scale to get correct 50/50 parts to mix)
good luck in your task to follow
That trailer is a bit of a wreck. The gooseneck design leaves a lot to be desired in the way of bracing and tying it into the chassis of the trailer. I would get some aluminum angle and run across the front so one leg of the angle is under the trailer, and the other runs up the front side. Then screw the uprights to that up high.
The tires need some really stiff foams.
No idea what is going on with the axles with the tires on there. I am guessing by the way they are wobbling the guy that built it went pretty lazy with the design there.
Take a wheel off and show some pictures of the axles.
Started taking apart one of the axles.
It seems to be a printed cover around the axle. If I remove it it will not go back on so we aren't doing that yet.
As it is NOW I can still use it just put the axle and springs back on .
@tntpoof no i dont have a welder or welding skills hell I'm just learning (poorly) to solder
I DO however have a friend with both that said he'd be happy to help out
Ideally he will just stand and help me and let me do it myself to learn but haven't gotten to that point in conversation yet, we have just talked about willingness to do it .
Today I'm going to a lot to take some photos of a few trailers to see how to make mine more like their's.
I've never made anything before fml what a wasted life.....
I digress
These ancient wheels aren't coming apart
The screws are fused in and I've snapped 3 off trying to separate them so the foams (or lack thereof) will have to remain a mystery
I kind of want to make it taller so I can use a larger wheel for then
A small 1.9 maybe? I have a proline trecher that's not much larger than these may see about working that in
Busy busy at work lately and not much wrench time, ESPECIALLY when I'm not 100% sure where to start...
Oh, those axles are terrible. No bearings... wow. Those are just going to grind up any wheels you throw on there, and they will just get sloppy again like you have seen already.
I am betteing those are just a couple short pieces of all-thead theaded into each end of the 3d printed pos axle tube. I bet it doesn't go all the way through.
I bet those springs used to be arched the other way too. They weren't designed properly.
Sorry to say, but if it were me, I would keep just the aluminum deck and scrap everything else. You're wanting to haul heavy stuff with that trailer, and by the time you fix everything wrong with it, you could have built a new one with angle iron and c-channel.
Fabbing up a new axle housing to utilize bearings will be the hardest part.
Here is how I would do it, but it would require some fab work, welding, and some machining.
Rectangular tube with a short section of round tubing welded under it. The length of the round tube would need to be determined by buying a pair of 2wd buggy front axles, bearings, bushings, etc. Then both ends of the round tubing would need to be machined to accept bearings. You would want the length of the tube to be just so, so the screw in the end of the axle clamps the two bushings on the inner races of the breaings. Hard to explain, but maybe this will help. Basically, if you slid both bushings onto the axle, then measured how much of the axle was sticking out, the tube needs to be just shorter than that.
You can buy metal leaf springs in 1/10 scale from various shops. RC4WD makes some.
Other than that, I can't really help ya much as it's all design and fabrication, which will all depend on your skills, and what components you have available. It's a tough project to take on if you don't have the skills. But you can learn. It just takes trial and error.
Good luck.
Oh, and here is how leaf springs should work. And is a similar axle design utilizing flange bearings pressed into the 3d printed axle tube.
I was thinking very similar
It flexes horribly from just 2 trucks on it
I'm trying to come up with a shopping list
I know I going to need around
10 feet of aluminum angle for the 2 sides using 3 feet for each side
If I can't get my bro to weld it for me I'm going to braise? It. It seems to work for other people
Map gas torch and some braise
Then another 3 feet or so? For the neck
I'm looking around tho
I wish those axles @Chubaka linked would work
that would simplify things a while lot
I wish those axles @chulinks would work
I'll try to find it. I've seen some people make axles out of aluminum tubes.
quick question......
why can't i use axles from an rc? i happen to have a set of axles from the bouncer that would almost be long enough
You can. Many a redneck trailer round here has been built with truck axles. Ain't no reason you can't do it with an RC trailer.
And just think... you can buy hex extensions too to widen the axles.
The hard part is getting the suspension to mount up to the axles and trailer. But if yourgoing to fab your own trailer, that's not hard to do. Just a word of advice - get the springs or shocks out as far as you can for stability.
i need some tires that will supporst around 30 lbs before they squish to the rim, would the semi trailer tires i see hold up to the weight better?
I've been messing around with it a bit, i took off the dove tail as it was constantly catching on grass, I'm hauling crawlers and camping chairs with it. the dove tail was COOL but not functional for my purposes,
i think some of the axles on amazon will be long enough, but they dont have bearings, is just a piece of all thread in a case like what is already on the trailer and the same as the drink trailer. i have to tighten the hex down till the wheel wont move then loosen it up little by little untill the wheel spins freely otherwise I'm just in full brake mode. i dont like this. and the little tiny wheels. their ridiculous/ their old and sag when just 2 trucks are on it and I'm riding on the rims sif i put 2 camping chairs on it.... unacceptable!
30lbs tires??? Is it your "too many adult beverages rescue trailer"??? WHO is riding on this thing??? 🤣🤣🤣
lol I'm just hauling camping chairs from the tent at campsite to the venue for instance lol saying 30 lb as my max, it would typically be hauling ten to fifteen lbs
if MY friends pass out while camping their going on an inflatable mattress in the lake lol
but id also like it to haul 3 30 packs now that you mention it and that weight adds up quick
I've seen other people do it!! i want it so bad
