- Bomb Pop Island
- Racing
Haven't done rcs for a few weeks now. Just got a AMain package in. I got some new diff and shock oils for the buggy. 500k for the center diff, 35wt for the rear shocks and 15k for the front and rear diffs. I got a shock rebuild kit for the buggy and red front springs. I am applying the carpet set up to the dirt car. Also got some mini b stuff which will be on hold for working on until I can find a chassis to get. On AMain the mini b chassis is on backorder until May I think. Also for the mini b i need to Dremel out 2 stripped out screws and I need to solder up a motor wire. I got a PL body post kit for the slash so it is all locking caps and no more body clips. Also to note the body clips were coming out easily since the body mounts were so wore down. Next I got a losi camber gauge and protek ride height gauge. I got the 3 to 20 mm for 1/10 off road. They had one going from 20 to 50 mm so I think that one was for 1/8 scale. Currently I am color matching the body caps to the body. I am using left over lexan paint from duratrax. So slash and rustler are ready to go. Mini B is on hold and needs some work. The buggy I need to dial in camber, ride height, shocks and diffs. This is the first time going into the diffs since the build so I might learn something new when getting to them. Also something I forgot to mention was I got front red springs and a shock rebuild kit.
