Mine broke. So yes something a little more durable and to help with the half lean issueWhat do you mean by different- Bigger, stronger? What issues are you having?
How did you break fuel tank? If it leaked then it was most likely faulty, just get a replacement of the same part. I don't know much abut solving half tank lean issues sorry.Mine broke. So yes something a little more durable and to help with the half lean issue
I was having lean in was have a little bit of lean issues but mostly when it got to the half a tank.If the tank is cracked or leaks ,then it will cause lean issues!
The tank gets pressurized by the muffler forcing the fuel to the carb,
Yes I been reading about the violator tank. I was wondering do they still make them?Ofna Violator fuel tank is a great upgrade. It eliminates the "half tank lean" issue that the T Maxx tanks are notorious for. Requires minimal modification and your tuning will be more consistant. Otherwise, keep with the stock tank. Do not bother with the Proline fuel tank, they are junk. When tuning with the stock tank, tune with half a tank of fuel or less. This will minimize the lean issue
I can't find it anywhere.
Or use an external filter.I think some people use to use more fuel line an loop or make a roll to cure that problem
on some models that had that issue ,its an old trick!...
Actually you could just about any 1/8 buggy fuel tank but the Violator tank was the most popular back in the day.yes I been reading about the violator tank. I was wondering do they still make them?
OK great thanks for the helpActually you could just about any 1/8 buggy fuel tank but the Violator tank was the most popular back in the day.
http://www.ebay.com/itm/Fuel-Tank-J...464462?hash=item2c9bfac70e:g:I6IAAOSwXeJXepnO
these are the posts you use to mount the tank
http://www.ebay.com/itm/Traxxas-TRA...728095?hash=item2eee40ed5f:g:b-MAAOSwnDZUEyBs
Heres an old thread to explain how its done
https://traxxas.com/forums/showthre...l-tank-mod-questions&highlight=half+tank+lean
Well, I was running a 4 shock setup at the time, but the shock tower was still smashing the tank. With only 4 shocks, the RPM towers flexed when just sitting. They bent quite a bit if I just pushed the truck to the ground by hand.Wow! That's some serious flex!!! @olds97_lss
