easy rider
I built a big block tmaxx. Extended the chassis with a rcrnew kit. Dropped an alpha 5 port .28 in it. It’s a screamer. But, I’m having problems once I het below half a tank. When I’m ripping it around it runs great. But, I’ve got to keep fuel in the tank. Or it starts getting air in the fuel line and starts “missing”. At a tad less than 1/2 a tank. Everytime.
As it gets lower in fuel, it gets more persistent. I can fill it up, and raise Cain till it gets to about a 1/3 a tank. Then it starts again.
Please understand it is not a tuning issue. I’ve changed gaskets, springs, fuel lines. And, it doesn’t cut out if running a straight line wot. But, as it gets low, the sloshing around causes air bubbles in my line.
I’m running a short pressure line. And probably a 9-10” pressurized intake line from the tank.
I’m figuring a longer pressurized fuel line might fix it. Or, an inline filter might help. Maybe not but, I’m thinking it would. It’s a stock tmaxx 3.3 tank.
If I baby it once it starts getting low. By not whipping it around or running in rough terrain, I get about 7 minutes, per tank. My guess it if I didn’t have to start making my turns wide and slower to prevent the miss, I’d get 6:30 a tank.
It’s a fun truck but, deserves to have this fixed. I’d live to hear from you guys what you think would prevent this. Different tank, longer lines, filter, in line bulb,etc…???
