$350
well, same with my other cars, last year i quit my job so no more money to spend. anyways, i have here a buggy that is COMPLETELY taken apart, and most of the parts are cleaned. now then, i am selling the buggy with everything in the pcis EXCEPT:
the servos
the 9886 pipe (i NEVER used it, bought it to go with new engine then no more job.)
the on/off switch
buggy has a set of old tires that i use to run around on the street with, also has new uhm... proline uh.. mugshots?
anyways, i HATE to sell this car for so cheap when i paid over 600 for it initially but w/e.
anyways, the buggy itself NEEDS a new front shock tower. that is wh it went down and i never s[pent the 30 bucks to fix it. however, i DID get new bearings ofr parts and i got bearings for the uh.. steering rack. all new in the packages. in the pics the stuff in the big blue box i have cleaned to the best of my abiltiy and i was in the process of cleaning the other stuff. i pulled the two diff cases apart and the 13 and the 43 tooth gears are in perfect condition. the diffs are still smooth and filled with 5k/7k/3k i think maybe 1k in the rear. the buggy WAS upgraded. i added the metal radio tray posts and the metal wing cross bars AND the blue shocks, and the frotn anti sway bar. uhm... ontop of that it has a new wing (anthracite color)
when sold will include all extra parts i have for the buggy including the stock black springs and some otehr stuff here and there. new tie rod ends etc.
sigh.
anyways, to get the car running you need a clutch setup / engine / radio/ servos etc, and a new front shock tower. and to clean the remaining parts:
radio box
shocks
diff cases
regrease the diff gears
fuel tank
and wd 40 the universals
then rebuild it.
enoguh rambling heres the pics
if you want more ask and u will recieve.
http://img78.photobucket.com/albums/v237/razornmt/
the servos
the on/off switch
sigh.
radio box
shocks
diff cases
fuel tank
then rebuild it.
