Hello,
I was trying to install my new Fioroni clutch the other night on my OS .28XZ and could not get the nut "tight enough". When I would try to tighten the nut, the flywheel would just spin on the shaft.
I had no problems putting the Team Associated clutch back on it whatsoever. I guess I'll run the AE clutch a little longer. Not sure if I need a new collet or what.
Any ideas what to try? I did try tapping the flywheel / collet with a hammer to seat it first, but as soon as I would try to tighten the nut, the flywheel could just slip again. I even drilled the inside of the nut slightly to make sure the threads in the nut werent' bottoming out on the shoulder of the crank, and no difference.
Any help would be much appreciate!
