Faster going reverse?!
ohmygahitscoby
San Jose
Hmm, weird. My Sidewinder 5700kv is going faster in reverse. The manual says to flip the wires connecting the motor and ESC together to get it to go forward if you throttle (If I throttled, it would reverse). But now, it tends to go faster in reverse. The reverse gets to top speed faster and is faster (I can tell by the sound). Any suggestions?
BTW: I know there was a thread on it, the one if you scroll down a little bit, but I couldn't find the answer.
With the wires color-matched (white-white, red-red, black-black), did you ensure the servo reversing switch on the transmitters' throttle is set to "normal"? If set to normal, flip to reverse?
How about re-calibrating the ESC? When calibrating, make sure you pull full throttle first, then brake, then neutral (when the ESC prompts)?
That's about all I can think of off the top of my head.
Well, I tried recalibrating it, it doesn't want to. It thinks I'm going reverse when I hit throttle, so I have to do reverse for it to think it's throttle. I couldn't find how to change it to reverse on the controller, it's the one that came with the Readyset version of the ZX-5.
Edit: Nevermind, I found the reverse settings switch. Thanks for the help! It worked :D.
