Installing the rear A-Arms in itself is easy. Trying to get the setup procedures the way I want them still has me a bit confused. Ill explain this as it comes up.
First thing is to screw on the front lower suspension holder. Use the two long screws.
The next step is to decide what eccentric bushing to use. Others have suggested to use 3 degrees of rear toe-in. To accomplish this I installed the #0 bushing, one on each side.
Next slide the hinge pin into the lower A-Arm and forward into the bushing.
I'm impressed with the beefy arms and pins.
Here is where I'm getting a bit confused on the setup. Eccentric bushings need to be installed into the front suspension holder. These are to adjust the rear squat. I wanted to set the anti-squat to 1 degree. To do this would call for a #0 bushing. Here is the issue I'm confused about. So far the kit only included 2 #0 bushings that I used for the toe. I'm hoping that there are more un-used #0 bushings in the kit. If someone can tell me I'm doing something wrong or if there are more bushings that would be great.
I installed #1 bushings facing up to give me an anti squat of 2 degrees. I will change it later once I find more bushings or correct any errors I have made.
Slide the suspension holder over the hinge pins and use the 2 short screws to secure it into place.
Use the fat set screws (Down Stop screws) in the provided holes in the A-Arms close to the hinge pins. The setup calls for 3mm of the screw to stick out the bottom. We got lucky here. 3mm of the screw will be sticking out the bottom when the top of the screw is exactly flush with the top of the A-Arm.
Once everything is put together check to make sure that nothing binds up. It should all move freely.
_______________________________________________________
Several people have asked how I get good looking picks.
I wrote an article a while back and will place the link here.
https://www.rcnitrotalk.com/forum/showthread.php?t=19423&highlight=Studio
I'm using a Canon Digital Rebel with a 28-200 72mm lens.
Here are a few pics of my home made studio. Everything minus the camera and tripod costs well under $50.00 and is available at home depot.
