factory settings?
the hsn flush? i dont understand, its the exact same looking set up as the trx3.3 i made the lsn flush with the inner ring on the slide, but i need to no how many turns out the hsn should be when its factory
Sorry about that. I was referring to the 18 cvr and on the one I had the hsn is inside a metal sleeve. If you set it flush with the sleeve, that's factory. Hang in, someone will chime in with more info.
yea i just can't find much tuneing info on this .18TM but ill tell yea the topspeed is insane on it
