Esc Programming.
scoobydoo2u
VA
Ok, so here is the problem.
Being new to electric I have no idea what causes this, but I want to learn!
Watch this.
I am hitting full throttle, but sometimes it "lags" behind.
I am holding most of the weight of the RC18, just using the table to show what it does when it is actually pushing weight.
[ame=http://s166.photobucket.com/albums/u120/scoobydoo2u/?action=view&current=RC18RCNT.flv]
[/ame]
Now watch this.
This is full throttle, it eventually will blast WOT, but sometimes it takes forever and sometimes it will hit full throttle like it is supposed to.
[ame=http://s166.photobucket.com/albums/u120/scoobydoo2u/?action=view&current=11111.flv]
[/ame]
Any help would be greatly appreciated!
I have the "Starting Power" on Normal, that is the medium setting.
and the battery voltage was 7.76 just before videos.
I recognize that car :D.
The "Turbo lag" is due to the stock battery pack. It has sufficient voltage to get the motor going, but not enough of a "burst" to give the ESC the power needed for startup. Set the ESC to high-power startup, and it'll minimalize the lag. About the only way to cure that is going to either a better nimh pack or to lipo.
Thought you might;)
Ohh, ok.
It makes sense now, like I said I'm relatively new to electric( Other then a stampede that left a bad taste in my mouth because I never understood the importance of a good battery and charger.
Any ways, Thanks for your help!
I was thinking of going LiPo anyways so I guess I'll be in the market for a Lipo, charger, power supply, and a new steering servo..oops:hehe:
I love this thing..
Program the starting power to low and set the motor timing as low as possible, this might help but a nice lipo should eliminate that problem all together.
