truggy83
today I was running my Jato 3.3. I was running high speed passes with the body on. It was running around 190 degrees. Smoke was still visible from the exhaust. After running speed runs the engine would hang reving kinda high. If I hit the brake the engine stops hanging at high idle. The idle speed screw is set to the proper idle. I saw that a hanging high idle after a speed run normally means that the engine is running too lean. I let the car sit and idle for 1 minute and punched the throttle. The car bogged down before accelerating. From what I understand that means the hsn is too rich. So what gives, the car is hanging after acceleration like the engine is lean. Temps are somewhat lower than they should be and the car bogs down after sitting at idle like the HSN is too rich. Any ideas.
