Just got done putting together a kit and put an os engine in with a pullstart. I got it to start but something is screwed up with the gear on the crankshaft. It wont spin when I pull the throttle, but I can see the flywheel spinning, any ideas?
Is the flywheel that the clutch shoes attach to moving?
Also, I noticed that you were discussing a similar issue regarding the clutch and spur in a different thread within the stadium truck section. Are these the same problem or two different engines on two different RCs with very similar issues?
yes this is the same truck and engine, thought I would post it in the main forums to get some others opinions. ...
do you know the best way to get to the differential adjust screw? It says place an allen wrench through both the slot in the outdrive and screw. Which will lock the differential screw and outdrive together.
I think it is on the oposite side of the top shaft, but to get to it I have to remove the brake rotor so I don't think that is it.
