engine restorer and lubricant
Status
Not open for further replies.
I doubt that would be a good idea. It's not meant to be burned, so it may leave nasty residues and standard 4-Stroke ring compression is quite a bit different than the mated surfaces used in ABC engines, so its effects would likely not be what you intended. Also, mixing it into your pre-mixed fuel would probably bog things up, unless you mixed your own.
Additionally, if you race ROAR I think additives are banned. If you're not racing or your sanctioning body has nothing against additives you might try NitroBlast.
-- Res
thanks for the link. i was looking at it and just wanted to know.
Thread closed at thread starters request.
Status
