1. How do you tell if your crankshaft is bad? I see perfectly horizinontal scratch marks/rings/lines, on the crankshaft , but not the piston (see picture). Still, the engine runs fine to my knowledge with one quirck below. Anyway,HPI webpage makes it out to be a very serious problem to have horizinontal scratch marks so i'm kinda worried. I took a picture of it
2. If I killed the engine by plugging up the muffler stinger and after ran out of gas I always have a hard time starting it up again unless I turn the engine over at full throttle for a few seconds without the glow plug first. Keep in mind it always starts up immediately after I do the above trick, but rarely does it start when I do not.
Thanks,
a1m80t
Thanks,
a1m80t
