engine change
jimmy j
i have a spare schumacher menace engine that works fine,would like to fit it into my thundertiger ts4n ,is it possible ?????????
if the engine is blown in the ts4n, it wouldn't hurt to try it.
ok will try it thanks,the carb on the 12 engine opens by turning ,the carb on 21 pulls ond pushes..if that makes sense!!!
how do i connect 2 servo????
it might be kind of hard because the 21 has a slide carb (pulls and pushes) and the 12 has a rotary carb (turning) so you might have to move the throttle servo but if you can make it work that thing would fly
do u mean move the servo??? i can change arms on servo,dont know about moving whole servo
thats what you might have to do is mod the chassis and move the servo to a diffrent location on the chassis
