ARO is hygroscopic and traps the water in its molecules . . .
It's not the ARO that's hygroscopic,
it's the FUEL. ARO, like WD-40 and automatic transmission fluid, is extremely strong at RESISTING moisture emulsification, not "trapping" it. The idea is to coat the internals and drive out excess fuel so that any condensation that would be caused by the fuel cannot come in contact with the metals.
Tarant is correct in that you should run an engine dry at the end of the day. Invert the vehicle and empty the tank, but put the glow start on it and burn all the remaining fuel out of the tank.
Next look at this comment:
. . . .put a few drops of after run oil in the hole (don't use wd-40), turn the mill over a few times . . .
Many people do this. But it's unnecessary. One, you possibly expose the engine to even more dust even if you clean the glow plug hole well. Two, constant unnecessary removal of the plug dents and scratches the gasket and will lead to premature compression loss. Three, any ARO you put down the glow plug hole will blow out the exhaust port as soon as you turn it over as you describe. And four, for the real reason you don't need to do this - How does your fuel find it's way into the combustion chamber? Through the carb. A sufficient dousing of ARO in the air inlet combined with a few cranks of the engine is MORE than enough to get plenty of ARO into the piston and sleeve.
Also a large misconception is "a few drops." I'll quote OS engines:
"When you use after-run oil, 2-5 drops are next to useless." You need to drive out excess moisture and insure complete coverage of the engine internals. A few drops is a waste of time; you need to use at least half a teaspoon.
Lastly, the WD-40 argument: Plaidfish, I also was a grease monkey and have used WD-40 all my life. Yes, it is a water displacing oil, and got it's name from being the 40th formula they concocted for that purpose (see their website.) Many people do use WD-40 as an ARO.
However. WD-40 **also** contains solvents and acids. Acids are caustic. This means they can and WILL cause mocroscopic etching on aluminum and steel surfaces
over time. Since the primary purpose of ARO is
long-term-storage, this is why WD-40 is not the best choice for ARO.
Automatic Transmission Fluid (ATF) is by nature water-displacing oil. Marvel Mystery Oil is a paraffin-based lubricant known for it's cohesiveness. The absolute best and cheapest ARO you can use is a 50/50 mix of MMO and ATF. About five bucks will mix you up a triple-lifetime supply and you won't have to worry about being conservative with it. This mixture is also recommended by OS as an ARO substitute.
