Electronic Problems Once Again......
HPI-Killer
Axial Axle Twisting Guru
Northern Utah
Okay issue 1, when I turn right, after about 85% turn my motor and or esc acts like it browns out or just dies, theres a blue light on my motor when I engage throttle, and when I engage both throttle and turn I can see the light dim or borwn out. But what i dont get is my friend runs the same servo and battery type, but also runs the stock ae1 esc and 35t motor and he runs just fine, so that I dont get and dont know what to do.
Issue 2 is something I have had in the past but could not figure it out, when I go into reverse, my rig pulses as it backs up, not sure why.
Thanks guys :D
Long shot, but I would reprogram the ESC to your transmitter to see if the problem goes away.
Do you use an external BEC? If not then the internal one on the ESC may be having issues in which case you either need to use an external BEC or just get a new ESC.
You actually cannot program this esc, its a plug n play LRP AI f/b/r WP esc so its nothin special, I should have never sold all my crawler escs lol
