I file comm lathing under the same category as matched cells,
tire warmers, hand winding and over-charging stick packs. It's stuff for the racers. Just like alot of you guys said, I too have run my motors many, many hours without a re-build. I tried the comm drops (Blackdeath comm drops), but never really saw an improvment. A good electric contact cleaner and some good bearing oil is all I really use. I have tried the glass of water trick and was amazed at all the crud that came out of the motor, even after I hit it with some cleaner first. I would like to pass on that electric motors, depending on the number of winds, magnet type and configuration, etc., have a sweet spot. So many times I lost that sweet spot by changing the pinion or spur gear by as little as one tooth. Speed or torque would drop off and I would scratch my head saying it should be faster based on the gearing changes I made. And it was different with different motors. Same gearing for one motor might be even better with another motor, worse on others. I have to give a plug for my sons Stampede. He's running a Reedy 9 turn modified on 7 cells and this thing is stupid fast. After we're done running it, we use it to cook supper on it. It gets that hot !!
