Nope. I was accurate. Current/amperage is the flow of electrons. Voltage is what pushes the current. look at it this way... Current is jelly and voltage is considered to be pounds of pressure. you can push more jelly through a 1" pipe with 12 pounds of pressure than with 4 pounds of pressure. To flow the same amount of jelly with 4 pounds, you will need a bigger pipe. Does that make any sense? This is how you can have the same gauge wire for on a 6s esc that is powering a 550 high performance motor. More voltage... same amperage.
Therefore, if you have 7.4v and you are drawing 40amps, you will need a bigger wire than if you had 14v and drawing the same amount of amperage. However, then you get into wattage which would actually be 40amps with 7.4 volts = 21amps with 14v. Class adjourned, so it is time to wake up and go play.
I am Master Certified in automotive electronics, which means nothing in the real world except I know that W=VA.
