DIY Tire Belting
Texas
Has anyone ever attempted this? I have a fairly new set of tires/wheels on my Backslash, but they're not belted. And around 45-50mph these things turn to donuts. I was wondering if anyone has found a good way to belt tires themselves. I know I should just go buy new belted ones, but my money is going towards Christmas gifts right now. And I think it would be cool to DIY this too
Fishing line
Right on. I was thinking about using one long strand of copper out of a piece of #10 stranded wire and actually thread it thru the tire in a spiral fashion all the way around the center area and twist the ends together inside the tire. Then take another couple pieces and thread them thru the inside loops (inside of tire) from the first piece of wire. Then twist those ends together inside the tire. Glue tire back on.
I'm just worried that poking holes in the tire to thread the wire thru will cause them to tear apart. Guess only one way to find out huh?
The rope or fishing line goes around the lugs in the tread and holds the tire shape. No holes necessary.
I was also thinking of maybe using silicone or even Fix-a-Flat to go inside the tire to hold it all together. But if I knew of a glue good enough then all I would need is a metal band the right diameter glued to the inside of the tire. I think
I've had good luck with gorilla taping the inside of the tire to reduce ballooning.
I'm not sure about glue inside the tire. It seems it would be difficult to get even amounts uniformly so as not to cause balance issues.
I've seen the gorilla tape work well.
@Ritz413 used a glue method. He might be able to give some input
Well ....progress has never been made without trying some new stuff....I mean of course they are belted.
Perfectly trimmed drywall tape...View attachment 256030
A liberal amount of permanent spray adhesive...
And
And permanently "clamp" with the foam. .
If the tires are made of real rubber you should be able to glue something on it with biketire repair glue. In Dutch we call this: Solutie. This stuff makes the rubber you glue to another rubber start a process called vulcanisation. The two rubbers bond together and become one. There is no seam in between them when applied properly. This calls for an experiment!
keep it up and ill regale you with stories of what its like to burn your finger on mechanical speed control resistors. the uncontrolled bouncyness of friction shocks, and having to upgrade to ball bearings. and the limited range and radio interference of AM radios.
or maybe you'd rather hear about drinking Surge and listening to Limp Bizkit?
I've never done it any other way.
Turn the tire inside out cut a strip of duct tape almost as wide as the center section, tape it down with no overlap, smash the ever-livin' stuffing out of it to make sure it sticks, turn the tire back to right-side out, mount and glue.
