Digital Servo
Bkyd Basher
Stamford Ny
Hey guys, whats the deal with the digital servo, They are for the 2.4ghz setup? Can u use a standard 2055 with the 2.4 ghz setup?
Digital servo's work & perform alot better than a standard servo will. Most ALL Servo's will work with a 2.4 Gig system & alot of the better servo's 1 name "SAVOX".
Is a really good servo to get & alittle expensive for a RIG I have a SAVOX servo "for steering" in my T-MAXX & alot of servos require alittle more power to run them most guy's run a RX recever hump pack Mah's 1200 - 1800. I run a team orion 1600Mah hump RX pack for my SAVOX. & Standard servo's are pretty much THAT STANDARD & droped into most RTR Rig's & upgraded from there..
If youd like to learn the differences between digital and analog servos you can check out my youtube RC channel. I have a video on that topic.
[ame="http://www.youtube.com/watch?v=jpPOOEBBK44"]Differences between digital and analog servos - YouTube[/ame]
Ok thanks. So u can use a non digital servo,like the traxxas 2070 in anything and a digital servo like the 2075 in anything regaurdless of what rx and tx setup u use right?
Correct. You only have to worry about going past the end points on the Digital servos. As long as you don't go past the endpoints you will be fine.
